Forums >> Revit Building >> Technical Support >> Visible shaft in 3D view
Tue, Aug 10, 2010 at 7:21:11 AM | Visible shaft in 3D view
psmeisje
Hi,
i'm working on a project where i created a 3D-view showing the structure of my building, all the colums, beams and floors. Is it possible to make a shaft opening visible in a 3D-view? I would like to show the elevator shaft but i can't figure out how to make a shaft visible.
Tue, Aug 10, 2010 at 8:02:51 AM | Visible shaft in 3D view
You could create a family that is only visible in 3D and is set to transparent in the view you want it in.
Visibility of Shaft Openings in a detail view
Fri, Apr 17, 2009 at 11:13:42 AM
Shaft Opening Phase Visibility
Mon, Jan 2, 2017 at 9:42:25 AM
Wall Visibility in 3d structure view
Mon, Aug 6, 2007 at 1:13:55 PM
Shaft Problem
Thu, Jul 12, 2012 at 5:20:52 PM
shaft cutting beams
Tue, Jun 2, 2009 at 7:47:18 AM
Page generation time: 3.1409
