Forums >> Revit Building >> Technical Support >> how to know the material used in a specific object?
Tue, Aug 10, 2010 at 4:57:39 AM | how to know the material used in a specific object?
querosaber
 i did soem walls and later with paint i change the material . but later i dont know the name material . how i know the material used in the wall ? some comand to know the matrial used in an object?
Tue, Aug 10, 2010 at 7:27:54 AM | how to know the material used in a specific object?
There is no way to know what you painted it with.  You can re-paint it with default and it will revert to what you assigned it in the wall type.
Tue, Aug 10, 2010 at 8:11:59 AM | how to know the material used in a specific object?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Actually if you used the "Paint" tool to apply the material you can see the name of the material. Just go into the paint tool and hover over the surface of the wall and look at the tooltip that pops up. if there is a material applied to that surface it will list it in the tooltip
Tue, Aug 10, 2010 at 8:36:22 AM | how to know the material used in a specific object?
I had forgotten about that James ... good pointer.
Tue, Aug 10, 2010 at 9:01:16 AM | how to know the material used in a specific object?
querosaber
the name s material appears. thnaks a lot
Mon, May 9, 2011 at 1:14:23 PM | how to know the material used in a specific object?
grid
Thanks for the tip James - I wasn't aware of that.
Palm Springs Architect using Revit LT!
Apply material to object style not working.
Fri, Jun 15, 2012 at 7:33:23 AM
Hiding Surface Pattern For Specific Wall Material
Thu, Feb 21, 2008 at 10:47:29 AM
Revit Arch. 2013 - Material Take-offs on specific areas
Thu, Mar 7, 2013 at 8:23:26 AM
Material schedule not picking up materials in railing object
Fri, May 6, 2011 at 4:03:35 PM
adding material to a dxf object
Wed, Nov 9, 2005 at 11:13:34 PM
Page generation time: 0.3429
