Forums >> Revit Building >> Technical Support >> Cut plane
Wed, Oct 12, 2005 at 7:55:17 AM | Cut plane
JAIMERIOSJR
Hello there. I modified two door famiies, one six pannels sincle door and a pocket door six pannel by changing the interior and exterior moldings. on the foor plans I can see the top molding and I do not know how to show only the cut jams only. what do I have to do to show the jam sections only, not the head?
Wed, Oct 12, 2005 at 8:18:49 AM | RE: Cut plane
latemore
latemore Avatar
3 Stars: 2 Votes
i am a relative newby to families, but i have learnt that checking visibility on every element is rather important. have you checked the trims to see if they are visible when cut in plan etc? from looking at expert's families, i also notice they use parameters to control if an element is 'on' or 'off', so maybe check you have not changed something like that. you may need to upload your family so the clever ones can check it for you!
Wed, Oct 12, 2005 at 6:19:01 PM | RE: Cut plane
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Adjust the cut plane in the family so it cuts the door at the appropriate level.
Wed, Oct 12, 2005 at 7:22:54 PM | RE: Cut plane
JAIMERIOSJR
Mr Spot, how can I adjust the cut plane in the family?
Wed, Oct 12, 2005 at 11:44:56 PM | RE: Cut plane
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Exactly the same process as in the project. View properties-->Edit View Range and adjust the cut plane to a level that will cut you door at the appropriate level under all conditions if possible.
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:42 PM
Would like shadows to appear from above cut plane
Wed, May 2, 2012 at 1:22:44 PM
How to control where the cut plane is for families?
Sun, Nov 22, 2009 at 10:19:59 AM
high windows and cut plane
Mon, Mar 19, 2012 at 10:15:29 AM
Cut Plane as a parameter
Fri, Apr 17, 2009 at 12:37:12 PM
Page generation time: 0.7240
