26 Users Online (24 Members):
Forums >> Community >> Newbies >> Revit MEP - modilfy topography
2 Posts No Rating |
Hello, I have a issue and seeing if anyone can helo. I am using Revit MEP 2011. We received a Revit file and I need to modify the topography of the existing site plan. For some reason, when I select the topography, the edit boundary selection does not come up… I need to resize the existing bldg footprint. I tried filters and even placing a void in, but it does not work. Is it because Revit MEP don't handle topography and I have to use Revit Arch? Thanks in advance. H
I THINK YOU ARE RIGHT. I DON'T REMEMBER MEP HAVING A SITE TAB. USE REVIT ARCH TO EDIT THE TOPO.
2 Posts No Rating |
Kinda what I thought. Thanks for confirming it. H
Revit MEP or AutoCad MEP |
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP |
Wed, Oct 28, 2009 at 10:10:40 PM
building and topography |
Tue, Jun 23, 2009 at 8:17:08 AM
TOPOGRAPHY SPLIT PROBLEM |
Mon, Sep 22, 2008 at 2:51:42 PM
Revit 2015 - Underground Pipes Set Distance Below Topography |
Mon, May 4, 2015 at 1:04:32 AM
