Forums >> Revit Building >> Technical Support >> Repeating Detail in Families
Mon, Aug 9, 2010 at 4:18:39 PM | Repeating Detail in Families
camncam
A repeating detail would be very useful in a family I am creating. Is there a way to use the repeating detail tool in Families?
Mon, Aug 9, 2010 at 4:24:34 PM | Repeating Detail in Families
cbieser
1 Stars: 1 Votes
What is it you're trying to repeat?  Can you just array it?
Mon, Aug 9, 2010 at 4:31:44 PM | Repeating Detail in Families
Thread Post Kudo! #3
camncam
I am trying to create a landscaping drain, the type that goes at the bottom of a driveway or the like. It has a grate in the top of it and I would like to create the grate pattern as a repeating detail so that I can make the length adjustable.
I figure that if I lock the end of the repeating detail line to each end of the grate extrusion then the detail would update when the length does (thoeretically). Can you think of another way of doing this?
Mon, Aug 9, 2010 at 4:44:05 PM | Repeating Detail in Families
TKennedy
4 Stars: 8 Votes
I have made floor grates, and I just make the grate one solid extrusion and apply a Grate material that has a surface model pattern that looks like a grate. It's not absolutly perfect, but it looks like a grate and works just fine.
Mon, Aug 9, 2010 at 4:45:45 PM | Repeating Detail in Families
cbieser
1 Stars: 1 Votes
This sounds like it should be an array parameter set up in the family.  Sorry, I have a limited experience with these but it is a parameter with a conditional statement (formula) you set up so that it repeats at intervals based on the length of your pipe.  Check conditional statements in the user's guide and that might get you started.
Mon, Aug 9, 2010 at 5:12:01 PM | Repeating Detail in Families
camncam
Everyone keeps talking about this user guide. I don't seem to have it. What is it? Maybe I didn't check a box when I was installing Revit or something. Is there somewhere online that I can view it?
Mon, Aug 9, 2010 at 5:13:11 PM | Repeating Detail in Families
camncam
Never mind about the user guide, I searched for it online and found it. Thanks for the tips.
Mon, Aug 9, 2010 at 7:15:08 PM | Repeating Detail in Families
camncam
I've been looking into conditional statements etc but it still requires me to use some sort of repeating detail and then add a conditional statement to the length as I am placing it for that to work. I can't find a way of doing a repeating detail in a family though. Anyone have any other ideas on this one?
Just to summarize (so that the revit masters out there can weigh up the whole matter from the beginning) I am trying to create a drain with a removable cover, like you would find at the bottom of a sloped driveway. I would like it to be adjustable in length. I have created an extrusion for the drain and another for the cover. But I would like to show the slots in the cover in plan at least. This could be done with lines if it was to stay a single length but I hit a problem when I try to make it adjustable length. A void extrusion for these slots gives me trouble and keeps wanting to delete when I make the drain shorter, also I would have to have the void going metres past each end in case I wanted to make the drain longer. So I figured a repeating detail of a detail line component in the shape of one slot loaded into the family would work. But I can't find a way to do a repeating detail in a family. There it is, I think I need a true master of parameters to unlock this one for me!
Tue, Aug 10, 2010 at 9:09:20 AM | Repeating Detail in Families
cbieser
1 Stars: 1 Votes
I downloaded this family from this site a while back and I believe it is close to what you are looking for.  You can reverse engineer it to try to figure out what you need to do in your family, but I think the single grate was arrayed, and then set to a parameter that was created to divide the length by the size a single grate to calculate the number of grates.
Tue, Aug 10, 2010 at 9:14:20 AM | Repeating Detail in Families
TKennedy
4 Stars: 8 Votes
An array should work. Assign a parameter (Number Of Slots) to the array, then in the formula for the parameter you'll need a formula along the lines of "Length / Slot Spacing". Slot Spacing could be a length, or another parameter.
Tue, Aug 10, 2010 at 4:13:29 PM | Repeating Detail in Families
#11
camncam
Hey thanks guys, I have alot to learn about families.
Wed, Aug 11, 2010 at 1:48:11 AM | Repeating Detail in Families
#12
camncam
I finally worked this out and it was so simple I thought I would post it for any other poor sucker who follows this post to the same frustration I have just been through. If you download the example above and try to "reverse engineer" it, be sure that the "Grid" parameter that controls the array group is an Integer not text.
Mon, Jul 2, 2012 at 3:30:47 PM | Repeating Detail in Families
#13
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
This is very similar to what I'm trying to do...but what I can't figure out in that attached family is how the grid array is connected to the parameter of "grid"...??
repeating detail that can be stretched
Mon, Feb 18, 2019 at 4:23:08 PM
Repeating Detail Properties
Tue, Oct 23, 2012 at 6:59:15 PM
repeating details not there
Tue, Apr 1, 2008 at 6:12:53 AM
Repeating Detail
Tue, Jun 9, 2009 at 7:49:30 AM
repeating detail hatch
Thu, Feb 7, 2008 at 4:09:05 PM
Page generation time: 1.2332
