Forums >> Revit Building >> Technical Support >> Curtain wall schedule
Wed, Oct 12, 2005 at 5:08:22 AM | Curtain wall schedule
Pamfi
Hi, Is it possible to extract into a schedule all the components (panels, mullions, frames, materials etc..) of a curtain wall system? I would like to have a detailed list of these items. Thank you very much for your help. Florin
Wed, Oct 12, 2005 at 6:09:16 PM | RE: Curtain wall schedule
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes... View->New->Schedule... There are choices for Curtain Panels, Systems and mullions...
Thu, Oct 13, 2005 at 1:03:22 AM | RE: Curtain wall schedule
Pamfi
Thank you Mr. Spot. One last one: can I customise my curtain wall panel to read a specific wall type? (not just a simple solid extrusion and material) Thank you a lot. Florin
Thu, Oct 13, 2005 at 4:46:02 AM | RE: Curtain wall schedule
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not sure what you mean by that... Curtain wall panels can be as complex as you can make... Only limited by your family creation knowledge.
Thu, Oct 13, 2005 at 6:08:09 AM | RE: Curtain wall schedule
Pamfi
Mr Spot, I have to design a curtain wall panel as a composite wall - having concerete as core and exterior and interior finishes These panels are of various sizes - the system is known as AMVIC Building Systems (basically are reinforced concrete walls) See http://www.insulatingconcretehomes.com/ICBO_ER-5948.pdf#search='amvic%20wall%20systems' Are very good for seismic resistance and also for heating transfer isolation. I design the house using Revit and I would like to ectract a detailed schedule of all these panels. Can this be done please? Thank you, Florin
Thu, Oct 13, 2005 at 4:20:37 PM | RE: Curtain wall schedule
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can select a basic wall as a curtain panel, which should give you what you require.
Wed, Nov 19, 2008 at 1:26:13 PM | Curtain walls
Murox
Murox Avatar
I have the same problem I want to include structural famillies like columns and beams inside the curtain wall pannel familly but I can't load walls. Is there a way to load a wall style into this type of familly ?
Carl Veillette
Nothing is impossible ...
Curtain Wall/Screen tag and schedule
Tue, Dec 30, 2008 at 4:00:48 PM
Reporting parameter from curtain wall door in Curtain Wall Schedule
Mon, Dec 19, 2022 at 5:44:58 AM
11
Creating Curtain Wall Schedules
Thu, Sep 14, 2017 at 11:59:47 AM
Curtain wall area in window schedule
Tue, Jan 27, 2009 at 10:41:42 AM
Schedule curtain wall doors
Mon, Mar 20, 2006 at 11:54:56 AM
Page generation time: 0.9898
