Forums >> Revit Building >> Technical Support >> Rotating a family in elevation
Sun, Aug 8, 2010 at 2:14:20 PM | Rotating a family in elevation
bcthompson
bcthompson Avatar
Hi guys,
I'm using Revit Arch 2010 and I've got a hill on which I'd like to place a car, but I can't rotate the car to match the slope of the hill (i.e. the back wheels look like they're floating)
I can start the rotate command in elevation view, but when I try to complete the command I get the error: "Can't rotate element into this position." I've played around with actually editing the family to no avail, it only lets me rotate in the X/Y axis as well. I've searched these forums as well but haven't found anything directly relating to my problem.
Thanks for any help you guys might have!
Brendan Thompson
CAD Drafting - 3D Viz - Graphic Design
www.bct3d.com
Sun, Aug 8, 2010 at 2:22:11 PM | Rotating a family in elevation
bcthompson
bcthompson Avatar
Nevermind, I found another thread in which a helpful mod suggested "Edit the family and under Settings / family category & parameters, uncheck the always vertical option."
Which worked fine.
Brendan Thompson
www.bct3d.com
Sat, Sep 15, 2018 at 12:16:57 PM | Rotating a family in elevation
untidy
You have no idea how much time and struggle you have saved me by pointing out the "ALWAYS VERTICAL" check box
Thanks very much appreciated
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Elevation markers accuratly
Sun, Sep 28, 2014 at 5:01:46 PM
Rotating a mass in family
Fri, Aug 11, 2006 at 2:11:14 PM
Rotating Objects in Elevation/Section
Tue, Jan 27, 2009 at 8:17:15 AM
Page generation time: 0.9460
