Forums >> Revit Building >> Technical Support >> How do you create 3D PDFs in Revit 2010 on Windows 7?
Fri, Aug 6, 2010 at 8:57:27 PM | How do you create 3D PDFs in Revit 2010 on Windows 7?
amrybarczyk03
I need to create a 3D PDF from Revit.  I am using Acrobat Pro Extended to create 3D PDFs by capturing the 3D view.  However, this is not working at all. All the Adobe tutorials say to turn on the OpenGL accelerator, but the only accelerator I have an option to turn on is Direct3D.  I don't know if it is the problem, but when i turn on the accelerator, Acrobat doesn't even allow me to use the settings to capture the model.  When I have the accelerator off, I get as far as setting up the caputure, but Revit won't allow me to "print screen" capture.  Nothing happens in Acrobat when I print screen in Revit.  (it's supposed to put a view in Acrobat of the 3D model.)  I've done multiple Acrobat tutorials to try and get this to work, and it doesn't.  What am I doing wrong, or is the OpenGL driver the issue?
Thank you in advance to anyone that can help!
Sat, Aug 7, 2010 at 10:13:35 AM | How do you create 3D PDFs in Revit 2010 on Windows 7?
Most of us use the built in export to 3D DWF.  The reader for that is free and available from AutoDESK.
Sat, Aug 7, 2010 at 10:37:47 AM | How do you create 3D PDFs in Revit 2010 on Windows 7?
amrybarczyk03
Thank you, I am aware of this.  However, my client is requesting a 3D PDF.   PDFs are more universal and clients do not neet to download viewers, since almost every business has Acrobat and can view them on any computer.
Thu, Sep 1, 2011 at 11:03:53 PM | How do you create 3D PDFs in Revit 2010 on Windows 7?
lukej2000
Easy way -
http://whatrevitwants.blogspot.com/2011/09/create-3d-pdf-files-from-autodesk-revit.html
Windows 7 or Windows xp with Revit 2010
Sun, Aug 16, 2009 at 4:17:14 PM
Windows 7 and Revit 2010
Thu, Nov 18, 2010 at 11:54:09 AM
Revit 2010 & XP service pack 3
Thu, Dec 3, 2009 at 3:26:58 PM
3d PDFs
Fri, Jun 28, 2013 at 6:11:41 PM
Does Revit 2009/2010 work properly to on Windows 7
Thu, Jun 3, 2010 at 4:25:04 AM
12
Page generation time: 2.9666
