Forums >> Revit Building >> Technical Support >> How to wrap the foundation slab material
Fri, Aug 6, 2010 at 5:06:52 AM | How to wrap the foundation slab material
ichlove
Hi,
I am trying to create a  foundtion slab type, but somehow the material can not wrap with the wall.The wrap box can not tickable.
Attached pls find my problems in revit and the effect I would like to achieve.
Is ther anyone can help?
Thank a lot!
Fri, Aug 6, 2010 at 5:28:32 AM | How to wrap the foundation slab material
4 Stars: 205 Votes
Those layers have the same priority in Slab and Walls? That material "Insulation" is the same material and the same NAME in walls? Did you try to use the "Join Geometry" tool between that slab and walls?
Fri, Aug 6, 2010 at 10:36:30 AM | How to wrap the foundation slab material
ichlove
Join Geometry works perfectly! Thanks a lot!
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
sloped foundation slab to flat slab join
Mon, Mar 25, 2013 at 8:01:59 AM
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:11 AM
Slab Foundation Questions
Fri, Mar 7, 2008 at 10:56:28 AM
Slab in foundation plan
Wed, Dec 21, 2005 at 5:10:28 PM
Page generation time: 3.1671
