Forums >> Revit Building >> Technical Support >> Spot elevations off by 1/4" ?
Thu, Aug 5, 2010 at 8:11:48 PM | Spot elevations off by 1/4" ?
LaryssaTLS
I keep running into a problem with my spot elevations reading 1/4" less than they should?
I have the type set to read decimal feet with two decimal places. I have (for example) a wall that is constrained to a top elevation of 80.00  when I try to take a spot elevation of the wall it is reading 87.96.  This is frequently happening in the project. What am I doing wrong?
Thanks for the help Smile
Thu, Aug 5, 2010 at 8:13:30 PM | Spot elevations off by 1/4" ?
LaryssaTLS
Sorry...forgot to mention I'm using Revit 2011
Fri, Aug 6, 2010 at 8:50:32 AM | Spot elevations off by 1/4" ?
The units on these tags can be set independent of the project units.  Check your tag's unit settings.  I bet they are rounded....
Fri, Aug 6, 2010 at 12:36:47 PM | Spot elevations off by 1/4" ?
LaryssaTLS
Thanks for replying Smile
The spot elevation tags are set to round to two decimal places.  This should not throw off the measurements by .04'  Maybe I am looking in the wrong place. Is it a project settings issue?  I am looking in the edit type properties box.
Fri, Aug 6, 2010 at 12:45:10 PM | Spot elevations off by 1/4" ?
If your tag units are set correctly, then it could be that the point you are trying to identify is not where you think it is.  I like to model with the best accuracy I can attain.  If your project units are rounded - chek that then add a finer dimension style and check your model.
Fri, Aug 6, 2010 at 12:51:23 PM | Spot elevations off by 1/4" ?
LaryssaTLS
I see. Ok, thanks for the tip. Thats really helpful.
Wed, Aug 11, 2010 at 4:41:55 PM | Spot elevations off by 1/4" ?
LaryssaTLS
This problem has been solved...and it was easier than I thought.  The Level 1 in our model (which elements are being modeled off of) was off by a fraction.  Moving the level in elevation solved everything.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:28 AM
Spot Elevations higher than 3000 feet???
Thu, Sep 8, 2005 at 6:21:14 PM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:54 PM
13
Page generation time: 6.9235
