Forums >> Revit Building >> Technical Support >> wall type
Thu, Aug 5, 2010 at 6:41:09 PM | wall type
AndreD
I am fairly new at Revit so you'll see me here quite often....
For some reason my wall pull down menu is only offering me a couple wall types where on a different drawing file it shows all of them how it's suppose to! What's going on??
Is it possible to create a axonometric section and render it?
While I am here, can anyone recommend a GOOD book on Revit Architecture 2009?  Thanks!
Fri, Aug 6, 2010 at 5:02:29 AM | wall type
4 Stars: 205 Votes
"For some reason my wall pull down menu is only offering me a couple wall types where on a different drawing file it shows all of them how it's suppose to! What's going on??" - Did you "PURGE" that file? i think so, that's why you only have a couple of wall types.
"Is it possible to create a axonometric section and render it?" - Create the section where you want, go to a 3D view and in the right side you have the "View cube" right click then "Orient to view > Sections" and select the section view you want, then you can render that.
"While I am here, can anyone recommend a GOOD book on Revit Architecture 2009?" - There are several good books,  "Mastering Revit  Architectural 2009", you choose the author....
Mon, Aug 9, 2010 at 11:00:27 PM | wall type
AndreD
Thanks for your feedback!
1.The purge didn't work....it's still missing all my drywall assemblies....
2.The section-render worked just fine, thanks!
3. The book name sounds familiar, I will give it a shot.  Is it the same you used, if any?
Tue, Aug 10, 2010 at 8:05:08 AM | wall type
Ty was saying that you must have purged your wall types, that is why they are missing.  Now you will ahve to reload them if you have them defined elsewhere.  You can copy paste or transfer project standards.
Tue, Aug 10, 2010 at 8:37:54 AM | wall type
AndreD
oh...I got it now....I will try to do it as said, thanks.
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Sweep vs. Wall Type
Mon, Mar 7, 2016 at 10:36:59 AM
parametric window should recognize wall type!
Wed, Apr 12, 2006 at 7:44:20 AM
Customizing wall type properties
Mon, Oct 31, 2011 at 7:55:30 AM
Brick will not wrap to new wall type
Thu, Apr 28, 2011 at 10:18:56 AM
Page generation time: 2.1645
