Forums >> Revit Building >> Technical Support >> 1 deg pitch
Tue, Oct 11, 2005 at 9:31:18 PM | 1 deg pitch
cadjockey
Hi all, I am trying to create a roof with a 1 deg pitch. Revit tells me it can't create the roof with this pitch. The best it can do is 3 deg. Is there a default setting I need to adjust so that a 1 deg pitch is possible. cadjockey
Wed, Oct 12, 2005 at 3:44:42 AM | RE: 1 deg pitch
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There are no settings for minimum pitch that i no of and i an having no problems creating a roof with a 1 degree pitch...? What type of roof are you creating? Is it sloped glazing?
Wed, Oct 12, 2005 at 4:03:19 AM | RE: 1 deg pitch
latemore
latemore Avatar
3 Stars: 2 Votes
i just tried mr spot's suggestion of a 1 deg roof - no issue. at the risk of stating the obvious, is your sketch fully closed? is each slope side at the correct angle?
Wed, Oct 12, 2005 at 9:51:36 PM | RE: 1 deg pitch
cadjockey
Hi guys, The roof is a very simple form. I have created a simple roof structure : a 200mm structure layer and then a 50mm finish layer I have called sheet metal. The roof footprint is a simple square and the sketch is closed. I have toggled three sides and left one side un-toggled (at my box gutter) in order to create the slope angle. The roof is based on a common wall plate level and offset as required. This should be simple. Is it a glitch with version 7.0 as this is what I am currently using. cadjockey
Wed, Oct 12, 2005 at 11:50:18 PM | RE: 1 deg pitch
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Shouldn't be a glitch in version 7 as i don't remember every having issues with that as i'd often have 1 degree pitched roofs. When you explained it have you got 3 sides defining slopes? or 1? The side to host the gutter should be the only slope defining line. Unfortunately i don't have a copy of Revit 7 installed to test...
Thu, Oct 13, 2005 at 12:12:58 AM | RE: 1 deg pitch
cadjockey
Mr Spot, The only side with a pitch is the gutter edge. cadjockey
Thu, Oct 13, 2005 at 12:29:09 AM | RE: 1 deg pitch
latemore
latemore Avatar
3 Stars: 2 Votes
a thought - have you put negative 1 degree on the slope defining edge by any chance? i have managed to use negative slopes at the 'head' of a roof, and it works. also, based on many roof comments in revitcity, maybe you should try a slope arrow?
Thu, Oct 13, 2005 at 2:28:32 AM | RE: 1 deg pitch
cadjockey
I found the problem. You cannot have a pitch lowere than 3 degress if you have your rafter cut set to 'two cut square'. At least with version 7 cadjockey
another double pitch roof question!
Thu, Jun 14, 2007 at 10:42:50 AM
Pitch Formula
Wed, May 2, 2007 at 9:34:35 AM
Duel Pitch Roof
Tue, Feb 10, 2009 at 2:11:10 PM
Bay window roof pitch
Fri, Apr 7, 2006 at 1:01:50 PM
Double sloped hipped roof
Mon, Jun 27, 2011 at 2:18:55 AM
Page generation time: 1.4341
