6 Users Online (4 Members):
Forums >> Revit Structure >> Tips & Tricks >> BLUE SECTION CUT SYMBOLS
5 Posts No Rating |
CURRENTLY I AM PRINTING SOME DWGS FROM REVIT TO PDF. BUT THE SECTION CUT SYMBOLS WILL NOT PRINT BLACK. IS THERE A WAY TO CHANGE THE COLOR OF THE SYMBOL FROM BLUE TO BLACK?
The blue indicates the view is not placed on a sheet. Place it on a sheet and it will turn black. Otherwise, this is a system setting and I don't believe you can change it. BTW - In the print setup, you can choose not to print these at all since there is no references....
Edited on: Thu, Aug 5, 2010 at 10:54:18 AM
5 Posts No Rating |
THEY ARE REFERENCING VIEWS AND THEY ARE STILL BLUE. I HAVE THEM REFERENCING DRAFTING VIEWS AND THE VIEWS ARE PLACED IN A SHEET... BUT STILL BLUE
Now I understand what you are asking. For almost everybody, when we print revit to PDF or printer in B&W or in color, the blue section cuts (views on sheets) always print black even though they are blue on the screen. I did see where someone else asked this question but I only saw it once and I did not see where anybody had an answer. ....
5 Posts No Rating |
WHEN I PRINT TO PDF. I SELECT PRINT BLACK IN THE ADOBE PRINT OPTION. BUT THEY COME OUT "GRAYED" TO BEST DESCRIBE IT BUT NOT BLACK.
5 Posts No Rating |
DUH!!! NOW I GOT IT. I DIDNT EVEN BOTHER TO CHECK IN THE PRINT OPTIONS IN REVIT!!! I WENT INTO PRINT SETUP UNDER APPEARANCE\COLORS. SELECT BLACK LINES. PROBLEM SOLVED. I DONT FEEL SO DUMB NOW THANKS FOR THE REPLY.
Some levels blue, some black |
Thu, Jun 16, 2011 at 7:08:05 AM
Color of the Cut |
Mon, Dec 28, 2009 at 1:44:40 AM
My section cut symbols don't show on the floor plans |
Thu, Apr 10, 2008 at 8:08:11 PM
Blue items show up red |
Mon, Dec 9, 2013 at 4:14:26 PM
DIMENSIONS OVERRIDES |
Mon, Nov 14, 2005 at 11:01:59 AM
