Forums >> Revit Building >> Technical Support >> Wall opening affects wall joins
Wed, Aug 4, 2010 at 7:12:05 PM | Wall opening affects wall joins
spacey
When I create a wall opening in this stacked wall, my corners are no longer joined neatly mitred
(Revit Architecture 2011)
Thu, Aug 5, 2010 at 5:18:33 AM | Wall opening affects wall joins
4 Stars: 205 Votes
After you create the stacked wall you can disassociate the SW, just select then right button, it's like you can "explode" that wall in two and work in them separately....
Thu, Aug 5, 2010 at 5:41:36 PM | Wall opening affects wall joins
spacey
Thanks Typhoon,
That worked, I am just not sure why! Does a stacked wall need to be treated as separate walls when items are inserted?
Fri, Aug 6, 2010 at 5:05:05 AM | Wall opening affects wall joins
4 Stars: 205 Votes
"Does a stacked wall need to be treated as separate walls when items are inserted? " - I think that's what you must to do when you work with stacked walls...
Cheers
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Wall Openings
Mon, Mar 9, 2009 at 2:40:22 PM
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
Wall Joins
Tue, Feb 3, 2004 at 6:37:20 PM
Page generation time: 1.6094
