Forums >> Revit Building >> Technical Support >> Browser reset at startup
Wed, Aug 4, 2010 at 3:16:54 PM | Browser reset at startup
nietsen
I've set up my broswer with various viewtype groupings (type=View Type with Folders set to Group by Family and Type then Views).
Everytime I reopen the central, the brower's viewtype settings is reset to it's default (type=all) resetting the folder ordering back.
Is there a way to lock the view type properties?
Wed, Aug 4, 2010 at 3:17:44 PM | Browser reset at startup
nietsen
Forgot to mention, this is Revit Architecture 2011
Wed, Aug 4, 2010 at 3:25:00 PM | Browser reset at startup
I believe that has to be set in the central file.  In other words, create a new central from a file that has the browser set like you like.
Why are re-opening the central?  I know that some people recommed that but we have an office of 20+ users and we almost always just use our local files and re-load latest at the beginning of the day.  Making a new local every day is overkill and really bogs down the network if you have large projects.
Wed, Aug 4, 2010 at 4:01:27 PM | Browser reset at startup
nietsen
Oh no, this is how we work as well...
It's just everytime you we started working in the file it would be reset. I will try what you suggested and will update afterwards.
Wed, Aug 4, 2010 at 5:12:20 PM | Browser reset at startup
nietsen
AHA!
Problem solved.  Thank you very much!
properties and project browser windows reset
Thu, May 9, 2013 at 3:13:39 PM
Material Browser Help
Tue, Oct 13, 2015 at 12:12:31 AM
Startup Huge Icons
Fri, Aug 31, 2012 at 2:23:24 PM
Reset Instance Parameters
Wed, Apr 24, 2013 at 3:25:59 AM
Maximizing Main Window on Startup
Thu, May 24, 2012 at 1:47:12 PM
Page generation time: 0.0798
