Forums >> Revit Building >> Technical Support >> window family array problem
Wed, Aug 4, 2010 at 2:21:49 PM | window family array problem
johnsonsara
I have an arched window that I want to add a brick soldier course around.  In the window family I'm trying to array model lines to represent the brick.  It seems all of the arrayed lines pile on top one another in the 2nd position.  I have it set to "last" not "2nd".  The same thing happens when arraying in a straight line.  Any suggestions?
Wed, Aug 4, 2010 at 4:55:16 PM | window family array problem
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
read your help menu about arrays. when you begin your array set it to radial and move the rotate tool center to the center of the radius you are trying to create. this is a 2' radius which accomdates 25 bricks nicely.
Wed, Aug 4, 2010 at 4:58:41 PM | window family array problem
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
didn't purge first.
Thu, Aug 5, 2010 at 2:46:17 PM | window family array problem
johnsonsara
Thanks, but I did move the rotate tool to the center of the circle.  I make arrays ALL the time, but for some reason it is JUST not working correctly for me in the window family.  The straight array does the exact same thing and piles the number of elements I tell it to in the 2nd array possition.
I couldn't open your link.  You must have 2011.  I'm in 2010 yet.
Family Array
Thu, Dec 31, 2009 at 3:46:22 PM
Array Family
Thu, Dec 31, 2009 at 3:01:57 PM
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:29:37 AM
Louvre Window
Wed, Jun 30, 2010 at 10:45:56 AM
Radial Array in a Family
Mon, Apr 11, 2005 at 8:56:12 PM
Page generation time: 0.9160
