Forums >> Revit Building >> Technical Support >> How to trim a small part from a wall
Tue, Aug 3, 2010 at 1:36:58 AM | How to trim a small part from a wall
ichlove
Hi,
I have some problems about facade wall connection. Basically they are two elements, one is basica brick wall with insulation, another one is just 100 concrete strip, but I don't know how to trim a small part from a wall (BTW, I have tried cut geometry, but it doesn't work)。Attached is the effect I would like to achieve.
Thanks
79974_wall_connection_in_cad.jpg79974_wall_connection_in_reivt.jpg79974_wall_connection_in_reivt_when_use_cut.jpg
Tue, Aug 3, 2010 at 3:38:22 AM | How to trim a small part from a wall
4 Stars: 205 Votes
Why don't you use a simple Sweep or a Wall Sweep to create that concrete strip in that wall?
Tue, Aug 3, 2010 at 4:34:25 AM | How to trim a small part from a wall
ichlove
You are totally right, thanks Typhoon!
Tue, Aug 3, 2010 at 12:58:22 PM | How to trim a small part from a wall
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Just for the sake of resolution, the way to make cut geometry work is to create an in-place family, then a void extrusion.  Cut geometry with the wall now, before closing the family editor.
wall trim under an eave
Wed, Feb 8, 2006 at 12:15:12 PM
Revit general questions part 3
Wed, Dec 2, 2020 at 2:07:58 PM
12
Stone wall covers door and window trim?
Thu, Jan 3, 2008 at 8:50:32 AM
Door Trim Sweep in Perpendicular Wall
Wed, Aug 17, 2011 at 8:30:38 PM
Trim and frame does not adjuts to wall as expected
Wed, Mar 1, 2006 at 12:22:56 PM
Page generation time: 3.0370
