8 Users Online (7 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Move elements vertically in Revit Architecture 2011
Mon, Aug 2, 2010 at 4:08:31 PM | Move elements vertically in Revit Architecture 2011
Geeyou
Hi,
Back in the good ol' days of 2010 you could select elements (walls/floors etc), click copy, then untick the copy box to enable them to be moved vertically.
In 2011 this option of unticking the copy box has gone.... any ideas if it can still be done? Why did they get rid of this...it was so useful!!
Thanks
Gav
Mon, Aug 2, 2010 at 10:08:07 PM | Move elements vertically in Revit Architecture 2011
eldados
eldados Avatar
4.5 Stars: 8 Votes
correct. you can only copy walls vertically and by unticking Constrain. I can't see the option to untick copy anymore.
Integrator
KarelCAD
Tue, Aug 3, 2010 at 9:40:17 AM | Move elements vertically in Revit Architecture 2011
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Good old days of 2010 ?? I believe that was REVITs worst release : )
Uncheck the 'constrain' option to copy a wall or floor vertically from a section or elevation view, then delete the original?
Can't move component vertically
Fri, Apr 20, 2018 at 3:22:19 PM
Pin Detail elements to move with Nearby Walls etc
Fri, Aug 13, 2010 at 7:12:19 PM
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:53 AM
Why cant I move lights vertically?
Fri, Jan 30, 2009 at 11:43:01 AM
Imported CAD drawing, exploding, level association
Thu, Feb 28, 2008 at 11:13:54 AM
Page generation time: 2.8691
