Forums >> Revit Building >> Technical Support >> Working out door location for schedule
Mon, Aug 2, 2010 at 9:58:42 AM | Working out door location for schedule
archie456
3 Stars: 1 Votes
Hi,
Traditionally in our door schedules we always have a column which tells the reader which room the door is located within.
This is quite easy to set up in AutoCAD Architecture.
Is there a way to do this in Revit?
Cheers.
Mon, Aug 2, 2010 at 10:05:25 AM | Working out door location for schedule
In the door schedule..."Select available fields from"... To Room / From Room.  You will need to learn how revit determines the to and from.
Mon, Aug 2, 2010 at 2:08:48 PM | Working out door location for schedule
archie456
3 Stars: 1 Votes
Excellent - Thanks.
Tue, Aug 3, 2010 at 2:46:39 AM | Working out door location for schedule
archie456
3 Stars: 1 Votes
Hows can I use these in a Calculated Value?
Essentially, I want to show one room which each door is related to, I cannot just show either the 'From Room: Number' or the 'To Room Number' as they might be blank in the case of exteral doors.
Do I would like to do a Calculated value which says if one is blank, then use the other. Something like:
if(From Room: Number="",To Room: Number,From Room: Number)
This doesn't work, I get the error 'Improper use of boolean expressions'.
What am I doing wrong??
Cheers.
Tue, Aug 3, 2010 at 10:13:13 AM | Working out door location for schedule
Sorry... from the HELP - Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters  We have no formula operations for text except I believe =.
Tue, Aug 3, 2010 at 2:43:41 PM | Working out door location for schedule
archie456
3 Stars: 1 Votes
Well thats disappointing.
Its funny, I certainly thing RA is a better product than AutoCAD Architecture but in a few areas, such as this one, RA is way behind.
Cheers.
Tue, Aug 3, 2010 at 3:02:43 PM | Working out door location for schedule
Here is a possible fix... Declare a new variable.  number ... If (Number=1, To room,From room)... OK?  Not automatic, you will have to set it in the door family - instance fariable assigned in the project to doors.
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:48 AM
Door Schedule Problem
Tue, Sep 21, 2010 at 7:26:12 AM
Door Schedule
Thu, Feb 20, 2014 at 7:19:42 AM
Customized Door Schedule Needs Help
Thu, Aug 25, 2011 at 5:53:09 PM
Door Schedule
Tue, Jun 12, 2007 at 7:29:31 AM
Page generation time: 1.6974
