Forums >> Revit Building >> Technical Support >> Elevation Tags Greyed out and crop region
Mon, Aug 2, 2010 at 9:46:22 AM | Elevation Tags Greyed out and crop region
cryanbrandon
We are working on a project in which we are using design options and when i drop an elevation tag on the floorplan it will only snap to the exterior shell of the model which is link into our revit model for the interior.  If i drop the tag it imediatley greys out and i cant adjust anything on it.  I go to the view and even the crop region is greyed out.  Any ideas would be helpful.  Thanks
Mon, Aug 2, 2010 at 9:52:41 AM | Elevation Tags Greyed out and crop region
This is a problem currently in Revit.  You can not change views or modify them while in a DO.  Just DO edit none.  Make sure to set the VG of your view to the DO you want rather than automatic.
Mon, Aug 2, 2010 at 11:27:58 AM | Elevation Tags Greyed out and crop region
cryanbrandon
I change the VG what do you mean "Just DO edit none" where is this located.  Thanks for the help
Mon, Aug 2, 2010 at 12:42:14 PM | Elevation Tags Greyed out and crop region
DO edit none - I meant set Design Option edit to main model.  You can't be in the DO if you want to change the view settings.
No Crop Region is greyed out??
Fri, Jul 13, 2007 at 9:23:10 AM
Room Tags Outside Crop Region
Sun, Sep 10, 2006 at 8:05:26 PM
Elevation bugs show up out side of Crop Region on sheets.. Why?
Wed, Sep 6, 2006 at 7:38:06 PM
Can't get Crop region to be visible in my elevations views
Tue, Dec 2, 2008 at 8:42:39 PM
Crop Regions, Keynotes & Room Tags
Sun, Dec 31, 2006 at 7:12:23 PM
Page generation time: 0.7316
