Forums >> Revit Structure >> Technical Support >> Looking for Revit Structure Extension Text Generator
Mon, Aug 2, 2010 at 9:08:33 AM | Looking for Revit Structure Extension Text Generator
jjohnston
I've searched for Revit Structure Extension Text Generator or (Revit Structure Extensions 2009) and can't find it so far. This external tool is suppose to ease the pain of creating general notes in Revit. Any idea how I can get a hold of it?
Fri, Dec 3, 2010 at 10:35:06 AM | Looking for Revit Structure Extension Text Generator
TyMad
Not sure about 2009 but in Revit Structure 2011 if you install the Revit extensions pack and go to "miscellaneous" the text generator is located there. Have not used it yet though. Hope this helps
Mon, Jan 24, 2011 at 2:11:22 PM | Looking for Revit Structure Extension Text Generator
cmcc
I can't find this - what am i missing?  The only extension pack I see in the subscription center is the "Subscription Advantage Pack for Autodesk Revit Structure 2011" but the description makes no mention of the text generator.  Is this it or should I be looking elsewhere? Thanks.
Autodesk Labs - Structure Generator
Wed, Dec 14, 2011 at 5:07:26 AM
Revit Text Generator
Fri, Feb 4, 2011 at 1:33:36 PM
Help with Frame generator
Tue, Feb 24, 2015 at 8:09:16 AM
Extension for structure
Sat, May 23, 2009 at 5:17:53 AM
text generator in 2017
Thu, Jun 23, 2016 at 7:05:08 AM
Page generation time: 4.6180
