27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> arch way/ door way Constraint & tag
I'm using Revit 2010... I've created manipulated an existing doorway family to create a '3 point archway' family. I can not get the family to flex the height correctly. How do constrain the top sketch line to the top reference plane? All the family types except '5ft' type are not working. also how can i create a tag for this? Thanks in advance!
here you go. edit the sketch and see what I did (constraining the top of the arch to the reference plain)
Thanks eldados! I was not able to open the file because it was saved as a later version. Could you save it as 2010 version? Thanks again!
here is 2010. you should upgrade to 2011 though
Thanks! I know, I'm actually the only person using Revit in the office with just one project. This firm still uses dataCAD!? I never heard of the program until I started. Thanks again!
Create & reference door tag parametrics |
Thu, Nov 8, 2007 at 2:24:44 PM
Door Sidelight Constraint |
Mon, Apr 24, 2006 at 12:56:28 AM
Door Tag Locations. |
Wed, Aug 24, 2011 at 12:48:11 PM
How to create new Door Tag to our requirement?or edit existing |
Thu, Sep 16, 2010 at 5:23:09 PM
Wall Constraints invalid |
Wed, Jul 3, 2013 at 6:15:34 PM
