13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> nested void family
3 Posts No Rating |
Hi I'm trying to load and array a nested void into another family to create slots in rhs steel posts and regular spacings. The void family is a generic model and simply a void extrusion size is parameter driven. The post family is a sweep and when I load the void family it seems to give me no option to cut the post with the void. I can of course create voids in the post family and array them but you get the old message about "too many instances, try nesting a family" which is what I'm trying to do but with not much luck. Any help would be much appreciated. Cheers. Blair
blairmack |
What you are doing seems rather complicated. I would think a post is a simple form ... extrusion or whatever - and the voids are created as part of that from and set to cut it. One void - not multiple voids. (Remember - you can have multiple shapes in one extrusion (-be it a void or soild) just as long as the closed loops do not cross each other.... O O O could be three voids in one void description.
3 Posts No Rating |
Thanks for that but I'm trying to control the slot size and array length by parameters. That way this same slot can be used in multiple families I need. Oh well maybe it's not possible. Cheers.
blairmack |
Try making the void family using a face based template. Make your void, then make it cut the generic block that represents the host. Then when you load it into your post family, it will ask for a face as a host. It should then cut out whatever it is hosted on.
I have a different but related issue where I have made a void extrusion on a face-based template, and it loads up fine into my family and cuts the host correctly, but I have an object directly underneath the void's host that I would like to also get cut by the void. Is that possible? The void shows as extending through the 2 objects, but it doesn't cut the lower one. I tried using Cut Geometry tool, but it won't recognize the void for me to pick it (presumably because it's inside a nested array?). Any ideas?
Jason
Use Nested Void Family to Cut Host? |
Sat, May 28, 2011 at 10:39:48 AM
Nested Void Problems on Shared Families (doesnt cut nested family if its shared) |
Tue, May 10, 2016 at 8:39:49 AM
Void cut in nested casework family |
Tue, Oct 15, 2013 at 12:46:49 PM
Nested void geometry doesn't cut host solid |
Mon, Dec 6, 2010 at 3:18:43 PM
Void cutting nested families [ 1 2 ] |
Mon, Oct 21, 2013 at 10:42:49 AM
17
