26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Detail view
4 Posts No Rating |
Hello, I've been using revit for a while and i'm having problems with creating a detail view. I know how to create one, but i'm having problems creating blocking. But mostly I need to know if you can somewhat offset a finish in a ceiling. Here is an attachment of what it should look like, it is a curtain wall, and a compound ceiling. I need to mostly know if you can offset the finish so that only the gyp board can go past the cieling. The second attachment is what i have. If you can help me please do.
Have you looked into edit cut profile? This is a view specific (2D) tool that allows you to edit how each cut layer of an assembly looks when cut. You can use this to extend, hold back, remove or interrupt layers of walls/floors/roofs in a section or detail. You can read about it in your help.
4 Posts No Rating |
I didn't know about that thanks, but i can't seem to find that tool. What tab is it under (ex. modify, manage, view etc...)
Revit not open here but I believe it is a view tab item. BTW - the cut profile can be altered into any shape and can extend in any 2d direction.
Edited on: Fri, Jul 30, 2010 at 1:15:02 PM
4 Posts No Rating |
looks like that's what i needed. Thank you
Creating an Enlarged Detail View of a Detail I have Drawn |
Fri, Aug 31, 2012 at 7:05:29 AM
How do I show a detail callout in more than one view? |
Thu, Oct 7, 2010 at 1:22:09 PM
link detail drawing from another drafting view in the same project |
Wed, Oct 12, 2011 at 11:14:00 AM
Multiple Detail Numbers In View Title |
Mon, Apr 11, 2011 at 12:24:54 PM
CALLOUT DETAIL VIEW VS. PLAN VIEW |
Wed, Mar 10, 2010 at 2:04:47 PM
