Forums >> Revit Building >> Technical Support >> Stair by boundary - stair direction
Wed, Jul 28, 2010 at 2:14:17 PM | Stair by boundary - stair direction
erin
5 Stars: 2 Votes
Hi y'all -
I'm trying to make a lovely grand stair with curvy edges. I'm using the boundary and riser drafting tools, and I have no problem getting the shape right. However, I can't get it go in the right direction! (It wants to put the top part at the bottom, and the bottom part at the top.) I've tried drawing the boundary lines in all sorts of different orders, but I get the same result each time. Is there some sort of tool I'm overlooking, or a special trick, or something I should be chanting during a full moon?
Thanks...
erin
Revit 2011
Wed, Jul 28, 2010 at 4:53:05 PM | Stair by boundary - stair direction
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Look for a wee little arrow at the top or bottom of your stairs which will reverse them. At least using the run type of stairs allows for this I can't remember if it shows up on curved or not.
Mon, Aug 2, 2010 at 8:27:29 AM | Stair by boundary - stair direction
erin
5 Stars: 2 Votes
Thanks, I finally found it.
Everyone else probably already knows this, but just in case... Here are the steps for someone else - under the properties of the stair, click the box for "show up arrow," then when not editing the stair (this was my mistake - I kept looking for something in the editing part...), just click the little arrowat the end of the stair.
stair boundary
Mon, May 16, 2016 at 4:51:31 AM
Stair Direction Display Problem
Mon, Nov 12, 2012 at 3:47:24 PM
dual entry stair
Sun, May 29, 2011 at 11:05:33 AM
dual entry stair
Sun, Jul 14, 2013 at 9:34:27 PM
Curved monolithic stair problem
Thu, Mar 11, 2010 at 2:33:31 PM
Page generation time: 0.8566
