Forums >> Revit Building >> Technical Support >> Offset input not working correctly
Wed, Jul 28, 2010 at 11:24:55 AM | Offset input not working correctly
josta
1 Stars: 1 Votes
I'm running RAC 2009 with Windows Vista.  Since I switched to Vista (only because I got a new PC) the offset command has been different.  For example, when I want to draw a line offset by 3.5", in the offset box I would enter "0 3.5" (no quotation marks or apostrophe for the feet), but it would show " .50' 3" ".
It seems that when I enter the inches, the first number goes to the inches as expected, but then anything after that goes to the feet.  So I have to delete everything in the box and input it very slowly; sometimes it works that way and most of the time it does not. Most of the time it helps if I input it as " 0' 3.5" " (using the apostrophe)  but sometimes not. Does anybody else have this problem?
John Acosta ARA, Architect
Mountain Architecture, Big Bear Lake CA
Wed, Jul 28, 2010 at 12:04:53 PM | Offset input not working correctly
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
no you just simply type 0 space 3.5, with no other annotation. works perfect for me. If you want to type in inches you can type 0 space 48, and you will get 4'-0" offset
Wed, Jul 28, 2010 at 12:11:56 PM | Offset input not working correctly
josta
1 Stars: 1 Votes
Hi, Steve.  Yes, that is what I've always done, typing in 0 space 3.5 with no annotations .  When I do that, the box shows .50' 3".  Weird....
Wed, Jul 28, 2010 at 12:30:47 PM | Offset input not working correctly
Dingo46
Dingo46 Avatar
1 Stars: 1 Votes
That happened to me when using 2009 also.  (not Vista though) It seemed that if I didn't type fast enough, Revit would display the wrong offset.  I know that sounds crazy too.
Gary
Wed, Jul 28, 2010 at 12:52:16 PM | Offset input not working correctly
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
guess you need to upgrade to 2011
Wed, Jul 28, 2010 at 1:43:04 PM | Offset input not working correctly
erin
5 Stars: 2 Votes
This happens to me occasionally. Usually if I select another tool for a while it starts behaving normally again. Sometimes, I have to type only one numeral for whatever dimension, let it reset itself, and then go in and edit the typed dimension in the little box.
I don't think I've noticed this in 2011, but I think it happened in 2010 sometimes...
Wed, Jul 28, 2010 at 7:49:10 PM | Offset input not working correctly
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Same number of keystrokes to type 3.5"  as it is to type 0 3.5, less room for error, and your hand is right there by the enter key... Shift-apostrophe-enter is an instantaneous movement.
...I'm kinda weird about efficiency though.
Also, I opt to not use feet for anything around and under 3 feet, and just do the inches.   And my fractions... I trust computers to digest ".125" much better than "1/8".
Room schedule input when working from an Architectural linked file
Wed, Mar 26, 2014 at 3:38:18 PM
Filter Overrides
Thu, Sep 27, 2012 at 4:20:34 AM
Offset floor same level
Thu, Feb 12, 2015 at 3:50:34 PM
Possible to specify the starting offset object?
Thu, Aug 29, 2013 at 1:47:59 PM
Offset in Revit 2014 !!!!!
Thu, Jan 23, 2014 at 1:36:58 PM
Page generation time: 0.3248
