Forums >> Revit Structure >> Technical Support >> Interesting Rendering/Drafting Issue...
Wed, Jul 28, 2010 at 10:05:54 AM | Interesting Rendering/Drafting Issue...
ChrisBerghammer
Revit Architecture 2010 in Windows 7
 I followed the instructions to save the render as a .png and then start a new drafting view  and then place the .png over a .jpeg of a sky.
 I wanted to just print it out to see how it would look cause I have a slight white line around the whole image between the image and the background.  That's not the issue though.
 When I printed the image from RA2010, the rendering was fine, but the background image printed 180* from how I had it aligned.  So I did the obvious thing, and rotated the render 180* and it printed fine.  Now the problem is because I rotated the render, when you look at the background it looks as if the grass is the sky and the sky is the ground.  Atleast it prints right, but does anyone know why this would happen?
Chris
Thu, Aug 5, 2010 at 6:46:31 AM | Interesting Rendering/Drafting Issue...
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
DID YOU TRY SAVING THE RENDERING AS A TIFF INSTEAD. I NEVER SAVE AS A PNG
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:51 PM
11
rendering issue
Mon, May 21, 2007 at 1:39:08 PM
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Rendering Issue
Wed, Nov 30, 2011 at 10:21:49 AM
issue with rendering
Tue, Nov 24, 2009 at 6:18:48 AM
Page generation time: 2.2142
