Forums >> Revit Building >> Technical Support >> Interior Elevation Tags
Tue, Jul 27, 2010 at 3:52:39 PM | Interior Elevation Tags
artworx
Is there a way to create Interior Elevation tag to show square with circle inside and hatch outside circle (tringular shape) and show the view names at the 4 corners of the square (A, B, C and D) and divide the circle in 2 sections, the upper part to show the Elevation number and the lower part to show the Sheet number.  I know this only works if you're only showing 1 elevation but how do you do it if I have to show 4 Elevations within the room using only 1 elevation tag? Please let me know if you know a way to do it, I appreciate it.  BTW, I'm using 2011, thanks.
Mon, Aug 9, 2010 at 4:38:14 PM | Interior Elevation Tags
cbieser
1 Stars: 1 Votes
I think this is a family that comes with the program; all you have to do is load it into your project and create your elevation tag type (Manage tab, Additional Settings, Elevation Tags).
Mon, Jul 21, 2025 at 11:28:06 AM
2011 interior elevation tags
Thu, Dec 23, 2010 at 11:44:57 AM
Scaling Interior Elevation Tags
Fri, Mar 3, 2006 at 3:07:26 AM
Interior Elevation Tags in Detail Plan Views
Tue, Nov 9, 2010 at 8:06:17 AM
Similar Tags - Interior Elevation
Fri, Oct 24, 2008 at 10:32:16 AM
Page generation time: 1.1719
