17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Autocad Import distortion
Hi all, are any of you also getting distorted Autocad underlays when inporting for tracing purposes? i get a slightly warped autocad line when i zoom in and when i zoom out- its streightens, is this a graphic card problem? I cant seem to knwo exactly when i am tracing the loction of the walls and when the overlaps of comlumns and wallas are accurate thanks Eli
eli |
Do you understand that because AutoCAD and Revit don't play by the same rules that this c an cause problems? Revit works in a restricted way. Revit wants nice square and parallel lines and smallest units is 1/256". AutoCAD doesn't care and works to very small tolerances. Lines in AutoCAD that appear to be parallel are usually not in Revit. So be wary! The warped line you see is probably because the line is not parallel in Revit. OK... That being said... why trace it? Cleanup a CAD file and then you can import what you need. Again, be very careful because exploded CAD imports can cause problems. I always recommend importing into a junk Revit file where you do final Revit line / text cleanup and then copy paste into your project.
Edited on: Tue, Jul 27, 2010 at 7:16:50 AM
Snarky response, Mr. Moderator.
Thank you for all of your contribuitions to the site mitchyzero.
import to revit from autocad |
Sun, Mar 31, 2013 at 11:37:12 AM
Autocad Import Problems |
Tue, May 5, 2009 at 1:55:33 PM
Revit Crash when Autocad Site plan Import |
Wed, Jan 7, 2009 at 4:51:26 PM
import shapes form autocad |
Wed, Jan 24, 2007 at 8:50:30 AM
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
