Forums >> Revit Building >> Technical Support >> Linked AutoCAD file printing grey
Mon, Jul 26, 2010 at 10:07:25 PM | Linked AutoCAD file printing grey
Gohanto
I'm relatively new to Revit, and having a problem printing out a linked AutoCAD file through Revit. All of our Revit files print fine, it's just the sheet with the AutoCAD linked file in it (and only the AutoCAD components of the sheet).
 So far I've tried adjusting line weights in object styles (I can make the lines thicker and darker, but then that doesn't help the text in the AutoCAD file). I turned off "apply halftone". In "print setup" I set colors to "black lines". So far, nothings been a solution. Thanks for any help.
Linked DWG appears grey
Thu, Apr 11, 2013 at 2:12:06 AM
Printing question
Fri, Dec 14, 2018 at 3:20:22 PM
Line weight of text from linked AutoCAD files
Fri, Sep 23, 2011 at 3:12:39 PM
Invalid Dimension to linked AutoCAD file.
Tue, Mar 13, 2007 at 11:24:22 AM
Problem with autocad linked file
Fri, Mar 2, 2018 at 12:24:23 PM
Page generation time: 0.5623
