Forums >> Revit Building >> Technical Support >> Cheating a Floor Plan Cut
Sun, Jul 25, 2010 at 5:09:45 PM | Cheating a Floor Plan Cut
leothelionator
Unlike traditional 2d drafting, why does Revit have to be so literal in defining its section cuts?  Is there any way to adjust clip plane settings to pick up both a high window (5'-0" a.f.f.) and a lowered dock entrance door (3'-0" b.f.f.).  Normally, I would tweak the cut plane up or down a foot from the typical 4'-0" a.f.f., but as soon as I do this one of the two elements in question is lost in the view.  There are not enough high windows to justify creating a new high-window floor plan view, nor are there enough dock height doors to justify a dock and lowered level entrance plan.
Mon, Jul 26, 2010 at 7:39:19 AM | Cheating a Floor Plan Cut
This is the reason for plan regions.  You can place as many of these as you want on a plan and control the view in those regions.  The plan region is define by a line that you can turn on or off in the view but the region still shows as defined.  You can read about plan regions in your help.
Mon, Jul 26, 2010 at 12:54:42 PM | Cheating a Floor Plan Cut
leothelionator
Thanks, it works like a charm!  The plan region dashed perimeter line is not visible when printed, correct?
Mon, Jul 26, 2010 at 1:57:04 PM | Cheating a Floor Plan Cut
If it shows in the view then it prints.  Turn it off in VG under annotations.
Mon, Jul 26, 2010 at 2:00:29 PM | Cheating a Floor Plan Cut
TKennedy
4 Stars: 8 Votes
You should be good with leaving the plan regions visible. I've never turned them off, and they've never printed. I have a feeling they count as crop regions.
Mon, Jul 26, 2010 at 5:53:23 PM | Cheating a Floor Plan Cut
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
If you go to print, and hit the Setup button, you'll see that the default options have Ref/work planes set to not print, along with scope boxes, and crop boundaries.  In this location you can also choose to replace halftone with thin lines... I wouldn't recommend messing with any of this.  It gets confusing when display/print settings are... decentralized, and Revit is usually so good in this department.
Roof-based family is not cut in floor plan?
Mon, Sep 13, 2010 at 9:08:48 AM
TEACHER TRICKS TO TELL WHEN A STUDENT IS CHEATING
Tue, Mar 25, 2008 at 11:57:10 AM
Generic model cut plane & plan regions
Thu, May 20, 2010 at 6:44:22 AM
Framing Plan - Getting Walls Below Floor to Show Openings
Thu, Jan 6, 2011 at 10:11:23 AM
Cant see site features in First Floor Plan
Thu, Jan 31, 2008 at 7:10:59 AM
Page generation time: 2.5685
