12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Roof Rafters
6 Posts No Rating |
Hello, Thanks for the response. In regards to the issue of adding rafters to the roof, I was directed to the link http://www.revitcity.com/forums.php?action=viewthread&thread_id=10882 , I loaded a wooden framing material from the Strutural folder (as indicated in the previous thread) but I am not able to add it as rafter. How can I possibly accomplish this. Instaed I loaded a detail component- Roght cut lumber and used it to show/fake it as rafters in a section view....not at all sure if that would be aright thing to do. Any suggestion would be highly apprecitaed. Thanks
What I would do is use Beam System. I would define the working plane as the roof surface. Load beams, wood, steel, or what ever. It just has to be a beam. If you don't know how to use the beam system it is just like defining a floor with a direction for the span. Works good. Let me know if that helps.
----------------------------------- BallewDesigns.com |
drawing angled roof rafters |
Tue, Aug 18, 2009 at 11:53:17 AM
Roof Rafters |
Tue, Apr 8, 2008 at 2:41:45 PM
Custom rafters/roofing Revit 2012 |
Wed, Oct 9, 2013 at 8:31:55 PM
How to make a roof consisting of rafters and trusses? |
Mon, Feb 1, 2010 at 10:46:27 AM
Exposed Rafters- Revit 2012 |
Thu, Aug 9, 2012 at 9:18:10 AM
