17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Hide Objects between sheet and view
60 Posts No Rating |
Is it possible to "hide" an element or catagory from showing on a sheet layout, but leave it visible in the corresponding view? Similar to "Freeze" in Paper space only in AutoCAD. thanks
I don't think there is a way to do this. Why would you want to when you have some other choices through multiple views? We use sheet views and working views - that may do what you want. Also, remember that with view templates, you can assure that sheet views are always set correctly.
Hide/ Isolate objects question |
Tue, Mar 18, 2008 at 6:35:09 AM
Hide/isolate in view versus in print |
Sun, Mar 22, 2009 at 4:01:20 PM
objects in view on sheet set not showing up in PDF |
Wed, Jul 10, 2013 at 7:00:02 AM
Hide Imported from View |
Thu, Nov 13, 2008 at 3:45:20 AM
Hide Isolate |
Fri, May 2, 2014 at 2:34:08 PM
