Forums >> Revit Structure >> Technical Support >> roofing help
Thu, Jul 22, 2010 at 11:42:48 AM | roofing help
bellgroup
Can anyone help me blend these two roof together. I created them seperately and can not make them blend together. I want the rear side of the roof which is the side of house that is facing you to extend up to the ridge perpendicular.
Thu, Jul 22, 2010 at 12:06:49 PM | roofing help
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
send a capture in picture format i couldnt open that pdf file sorry
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Thu, Jul 22, 2010 at 12:44:45 PM | roofing help
4 Stars: 205 Votes
"I want the rear side of the roof which is the side of house that is facing you to extend up to the ridge perpendicular." - That's the problem, now you must CUT that part of the roof, just edit the profile and draw new lines
Thu, Jul 22, 2010 at 3:17:33 PM | roofing help
bellgroup
I'm not sure how to do that, can you explain it to me.
Thu, Jul 22, 2010 at 3:21:49 PM | roofing help
4 Stars: 205 Votes
Again, "just edit the profile and draw new lines, look at the images above....
Thu, Jul 22, 2010 at 4:32:34 PM | roofing help
bellgroup
Thanks for your help once again. Your advice was helpful. I got the forward roof to cut the shape it needs to be but the rear part I'm not sure how to edit the lines to fill in the space that was cut out of the forward roof. The lines of the rear roof go around the edges of the exterior walls not the ridge. Maybe I have drawn the roof with the wrong method, is that possible. Here is the new image of how it looks. If I should be using another method of doing roofs please let me know what it is called and any knowledge of it that I can find
Roofing Material Look alike
Wed, Nov 21, 2012 at 5:35:57 PM
sloping roofing
Wed, Mar 9, 2005 at 1:21:52 PM
Revit Roofing
Tue, Mar 23, 2010 at 2:30:31 PM
Altering roofing structure in section views R2012
Thu, Jul 19, 2012 at 7:32:50 AM
Tile Roofing
Wed, May 31, 2006 at 8:06:23 AM
Page generation time: 5.0042
