Forums >> Revit Systems >> Technical Support >> Pipe Crossing Display
Wed, Jul 21, 2010 at 9:56:59 AM | Pipe Crossing Display
Kaiya
Alrighty. So I'm using Revit Architecture 2010 and I'm looking at piping systems in plan. The pipe crossings where one pipe crosses over the other, seem to appear whitout any kind of white buffer or gap in the lower pipe. It's impossible to tell which pipes are higher and which are lower. If I zoom in a ridiculous amount, I can see a tiny white gap created by the higher pipe, but it's far to small to be any help with the drawing is printed.
I've heard this may be a problem relating to looking at things in Coordination view, with it's differences in showing hidden items. But I've tried Mechanical view as well and it still won't work. The strange this is that the pipe connectors are fine, showing a nice gap whenever they connect to a continuous pipe. I think it could also be a lineweight problem, but if I try to modify linework and put it back to it's category setting, I can't even click the piping.
 Any ideas would be more than welcome.
Wed, Jul 21, 2010 at 1:01:30 PM | Pipe Crossing Display
Dingo46
Dingo46 Avatar
1 Stars: 1 Votes
I do not use RAC 2010. We use MEP 2011. When we run into what you are describing, we go to MEP settings> Mechanical Settings and make sure the "Draw MEP Hidden Lines" checkbox is checked. In that same dialog box there are gap adjustments for the size of break for the lower element.  Maybe there is something similar in RAC 2010?
Gary
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:16 PM
Help! Revit highligts (floors/roofs/topo) Doesn't allow Crossing Window
Tue, May 20, 2014 at 10:16:20 AM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
Pipe crossing gap mystery
Thu, Aug 23, 2012 at 12:01:47 PM
pipe dimensions
Wed, Dec 2, 2015 at 7:47:03 AM
Page generation time: 3.8314
