Forums >> Revit Building >> Technical Support >> sidewalk split topo suface issues
Fri, Oct 7, 2005 at 10:30:55 AM | sidewalk split topo suface issues
pepsiqueen
pepsiqueen Avatar
Hi, I am trying to add sidewalks and curbs to a model of a sub division. i have tried spliting the toposurface so that the sidewalk is its own sufrace then raising it, but revit will not let me split the toposurface i have no idea why. I have split it into exactally 2 pieces, The sidewalk is set back from edge of street by a 2' grass strip. revit will not let me split topo into this grass stripe either. when i try to make the sidewalk a subregion, i sketch it all out and it looks perfect but when i complete sketch, sidewalk looks like a 2" stripe in the wrong place. any ideas anyone?
Fri, Oct 7, 2005 at 5:11:42 PM | RE: sidewalk split topo suface issues
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, if its ending up in the wrong place it might be an idea to check to make sure your work plane is parallel the view your working in... I would've thought that the work plane would be the toposurface and thus it shouldn't matter, but that is the only reason i can think of at the moment... Just set your work plane before drawing the sketch.
Curb & Sidewalk Sweeps that could be attached to site topo edges! Why not?
Wed, Apr 19, 2006 at 9:17:07 AM
Could Revit allow curb or sidewalk sweeps to be attached to site topo edges?
Wed, Apr 26, 2006 at 4:42:17 PM
ramps with multi slopes
Thu, Apr 23, 2009 at 12:30:57 PM
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:58 PM
How do I undo a split surface of my topo?
Thu, Oct 8, 2015 at 6:53:44 AM
Page generation time: 2.1298
