Forums >> Revit Systems >> Technical Support >> Rooms and Spaces from linked model (Revit MEP 2011)
Fri, Jul 16, 2010 at 10:33:09 AM | Rooms and Spaces from linked model (Revit MEP 2011)
SamLerman
Hello,
I just installed Revit MEP 2011. It doesn't have a good normal Help, where I can search, so I'm looking for help elsewhere..I have linked arch. model, and when I copy/monitor levels, walls, etc., it's not copying rooms and spaces, and I have to create them myself.I do something wrong?
Fri, Jul 16, 2010 at 11:52:46 AM | Rooms and Spaces from linked model (Revit MEP 2011)
First - Revit's HELP is probably one of the best so if you can't find your answers there, you are not using it correctly.  The copy-monitor process is well documented in the HELP and it will tell you what you can copy/monitor.
I do not use MEP but as I understand it, MEP uses different spaces then the architectural rooms.
BTW - Always look at the similar threads below your posts.  In this case, I see there is a video in one that addresses your problem.
Fri, Jul 16, 2010 at 11:59:27 AM | Rooms and Spaces from linked model (Revit MEP 2011)
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
The copy / monitor ability for rooms was removed I believe in 2009???
That was replaced with spaces in MEP.
Easy to do, set the architectural link to room bounding (in the properties of the link) and then simply place a space for each room.
With the link set to room bounding, the spaces will reference the properties of the room...including areas and volumes and names and pretty much anything else.
If you are using this for calculations, you will also want to place spaces into plenum areas and then set the properties of those spaces as such.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Jul 16, 2010 at 12:32:33 PM | Rooms and Spaces from linked model (Revit MEP 2011)
SamLerman
to brettgoodchild
Thank you, I just did so, but it did not take room names
Fri, Jul 16, 2010 at 12:36:24 PM | Rooms and Spaces from linked model (Revit MEP 2011)
brettgoodchild
4 Stars: 17 Votes
Sorry...I should have mentioned taht the default space tag does not reference room names....but you can easily modify the tag family and add the room name paramter.
                             ~ Abraham Lincoln
Fri, Jul 16, 2010 at 12:40:58 PM | Rooms and Spaces from linked model (Revit MEP 2011)
Well Sam.... you obviously didn't watch the video because it shows you very easily how to get the room information from the linked model.  wmv is in the thread below : http://www.revitcity.com/forums.php?action=viewthread&thread_id=12329
YOU CAN LEAD A HORSE TO WATER BUT YOU CAN'T MAKE HIM DRINK !
Fri, Jul 16, 2010 at 2:12:27 PM | Rooms and Spaces from linked model (Revit MEP 2011)
SamLerman
Well WWHub,
I know how to change Space to Room information, I had this video since when it was posted.
Instead pointing to my unknolage, you could try to help
My problem was - copying room info from linked model, thanks to brattgoodchild I got it, but it did not show up on my model. I found the problem - rooms were not visible.
Thank you
Sun, Jul 18, 2010 at 9:40:06 AM | Rooms and Spaces from linked model (Revit MEP 2011)
Sam, I was trying to help.  You did not indicate that you had viewed the video, had followed it and was still having problems.  You only said you had followed Brett's advice and "...I just did so, but it did not take room names".
We can only work with what you post ....
Revit MEP 2009 - Rooms, Spaces, etc...
Wed, Dec 24, 2008 at 10:18:50 AM
Rooms in linked Revit model
Thu, Jul 24, 2014 at 8:07:13 AM
Programming spaces/rooms in Revit
Fri, Jun 21, 2013 at 9:20:34 AM
MEP + Unoccupied Space??
Fri, Feb 19, 2010 at 2:53:14 AM
Rooms not displaying from linked architectural model - Revit 2018
Thu, Jan 17, 2019 at 2:41:26 PM
Page generation time: 2.2954
