Forums >> Revit Building >> Technical Support >> curved wall panels
Thu, Jul 15, 2010 at 10:28:30 PM | curved wall panels
joeinck
Revit 2009
i would like to make a wall panel to use on a greenhouse. everyone has seen them on greenhouses, but i am not sure how to get started making a wall type that is a series of curves.
thanks
Fri, Jul 16, 2010 at 7:09:59 AM | curved wall panels
4 Stars: 205 Votes
Like what? can you put some images to figured out?
Fri, Jul 16, 2010 at 7:55:46 AM | curved wall panels
If you want to use flat glass panels, then curtain wall systems should work.  If you will be using curved glass sections, then consider in-place (or parametric) families.  One in-place sweep could be glass and your mullions could be a family placed at intervals.
Fri, Jul 16, 2010 at 9:22:21 AM | curved wall panels
joeinck
thanks for getting back to me.
i have attached a pdf of a panel in plan view, they are pretty thin.
Fri, Jul 16, 2010 at 10:43:41 AM | curved wall panels
The answer you need depends on what you want.
Do you really need this shape modeled?  We use similar shaped metal wall panels (also floor/roof deck) and we do not model them.  For rendered views, we use a material that will render to look like the material and then in plan and detail views, we use 2D detail compnents to represent the shape.
If you insist on modeling this material, you can create a very simple family that is a parametric extrusion for length (the wavy form with a thickness is your profile).  If you wanted to get fancy, you could create the panel to the normal maximum width but have within the same family, a controllable void that would cut that back when you needed a narrower panel.
Fri, Jul 16, 2010 at 1:24:07 PM | curved wall panels
joeinck
yes, i do want this to be a "wall". I sketched the shape i needed as an extrusion, but i dont know how to take this from and make it an actual wall type, just like a 3 5/8" wall.
I am in over my head here, any hints on where in the help docs this is covered or how to begin.
I read WWhub' reply and i am still stumped.
thanks
Sun, Jul 18, 2010 at 9:26:46 AM | curved wall panels
Walls are system level components so there is no way of having this extrusion act like a wall.  As I said, for metal wall panels, we use a flat wall but assign it the material properties so that it renders correctly and that is a wall.  That material has a vertical hatch pattern so that it indicates the texture in 2D elevations.
curved curtain wall, straight transoms, curved panels
Tue, May 12, 2015 at 8:36:03 PM
Wainscoting in a curved wall
Wed, May 27, 2015 at 9:51:14 AM
Curved wall
Sat, Jan 15, 2011 at 1:41:20 PM
How to do a vertical reveal in a sweep in a curved wall?
Thu, Oct 22, 2009 at 2:04:26 PM
Random slidding panels on a curved facade ?
Tue, Mar 1, 2011 at 9:56:45 PM
Page generation time: 2.4923
