Forums >> General Discussion >> Wishlist >> Tree
Wed, Jul 14, 2010 at 4:57:42 PM | Tree
nlh86
I'm creating a sustainable treehouse learning facility and I want to use the tree trunk for support. Is there any way I can do that? I need a really large tree to accomplish this. Maybe revit has a tree trunk component by itself. I use sketchup but it renders white.
Wed, Jul 14, 2010 at 5:45:20 PM | Tree
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
You would likely have to model your own tree.  Shouldn't be too hard, especially if you're just focussing on the trunk.
  There aren't many good trees available for revit -- I had to make my own sitka spruces.   There seems to be an overabundance of flowering cherry trees or and the like, yet... the majority of us and our clients don't live in Japanese rock gardens.... As for rendering, finding a suitable bark material will be your challenge.  perhaps by playing with the size of an existing material pattern and its bump image you can get a good effect.    If it were me, I'd model bark, but I'm OCD like that.  I'd model a long irregular sweep, rotate vertical, and radial-array around the trunk... with a rough render apearance, BAM!  Megabytes...
Wed, Jul 14, 2010 at 6:46:29 PM | Tree
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
try google 3D warehouse, lots of stuff in there. looks like you modeled a telephone pole. you could reuse one.
Fri, Jul 16, 2010 at 4:02:34 AM | Tree
Thread Post Kudo! #4
nlh86
itsmyalterego: Not to say that wouldn't work..but creating families aren't my forte. Do you know of any familiy tutorials?
mbsteve: that isn't my design..it is just an example..here is my design
Fri, Jul 16, 2010 at 4:19:25 AM | Tree
nlh86
That is not my final design..I'm currently changing the materials to wood to give it more of a treehouse look. I'm also working on the wood/timber structure and framing
rpc tree
Tue, Mar 31, 2009 at 12:01:03 PM
tree render
Mon, Oct 13, 2008 at 2:12:37 PM
Cannot Edit Tree Height
Thu, Oct 3, 2013 at 1:38:21 PM
How to build tree roots in Revit
Tue, Mar 19, 2013 at 3:41:14 PM
car and tree families for plan, section and elevation drawings
Mon, Apr 21, 2014 at 9:34:09 AM
Page generation time: 2.6498
