26 Users Online (24 Members):
Forums >> Community >> Newbies >> Applying materials to new families
11 Posts No Rating |
I'm new to Revit and am not exactly familiar with how families work yet. However, I have applied a material to a new family I have created. It shows up in the family window/editor when its on realistic view, but when I try to load it into a project, it only shows a default gray material on the family. What step am I missing to get the materials to show up in the project itself? Any help would be much appreciated! Thanks.
PROJECT RULES - check the name of that material in project and see if have the right texture you apply in family
i dont know how much help i will be but i have just started ceating my own work with families and such and am havig the same problem but i think i have narrowed it down go to properties and then to apply new material a window will pop up click on the one that says defalt new material a new window will pop up go to the button in the top corner then press the button directly to the left of it annother window will pop up switch your material then press apply then exit out and move the window to graphics and check the box that says use render apperence then click apply xit out and press apply again then press ok and your done i hope i helped
Thank you a million times!!!!!!!!
Massing - Applying Materials to Imported Geometry from Rhino-HELP! |
Sat, Dec 10, 2011 at 6:30:09 AM
Applying different Materials |
Tue, Mar 16, 2010 at 9:20:04 AM
Setting the materials for symbol families |
Thu, Jan 20, 2005 at 11:09:39 PM
Applying Materials To Cover A Hole |
Mon, Mar 10, 2008 at 8:26:30 PM
replacing materials in multiple family files? |
Wed, May 6, 2009 at 7:13:40 AM
