11 Users Online (9 Members):
Forums >> Revit Systems >> Technical Support >> Array/group pipe connectors
1 Posts No Rating |
Hi, I made a parametric manifold and wanted to have it also array the pipe connectors, however revit told me it can not array pipe connectors.I tried putting the pipe connector into the group that is the valves that array and it then told me that you can not add pipe connectors to a group.This was anoying but i accepted it, however i have now seen it is possible, by adding the pipe connector to a group but I can't do it. Anyone help? Basically, i need to group a pipe connector onto a extrusion so i can array it in a parameter.As ive now seen in the mitsubish library on autodesk seek in file;HVAC_MAIN-BC-Controller_Type-GA_Mitsubishi.rfa Thanks.
Mechanical Equipment pipe connectors... |
Tue, Nov 18, 2008 at 11:21:28 AM
pipe connectors (HELP) |
Tue, Sep 22, 2009 at 9:34:52 AM
pipe connectors |
Mon, Jan 3, 2011 at 11:16:52 AM
Array association |
Tue, Nov 11, 2008 at 9:17:31 AM
visibility parameter for array group? |
Tue, Sep 11, 2007 at 3:11:24 PM
