Forums >> Revit Building >> Technical Support >> transparent glass in elevation
Mon, Jul 12, 2010 at 8:27:06 AM | transparent glass in elevation
Dafpfy
3.5 Stars: 11 Votes
Hi,
i have a glass railing in front of a window in elevation and i want my glass to be 50% transparant, so you can still see the glass and see the window behind it,
Is this possible?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Jul 12, 2010 at 11:43:19 AM | transparent glass in elevation
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
in what kind of display you want that? in hidden line you cant, so im guessing its in a color type of display
Mon, Jul 12, 2010 at 2:04:33 PM | transparent glass in elevation
Bimman
Bimman Avatar
1 Stars: 2 Votes
you change your material sttings for the glass to be 50%. but that is only going to work in a 3d view.  you could set your 3d view to front, back, side etc.  that way you will see through the glass.
PWD
Mon, Jul 12, 2010 at 2:35:31 PM | transparent glass in elevation
ttiefenbach
ttiefenbach Avatar
3 Stars: 2 Votes
In the railing family, you could change the visibilty of the railing to be hiden in front elevation then show symbolic lines instead.
Revit Architecture 2011
Mon, Jul 12, 2010 at 2:38:50 PM | transparent glass in elevation
TomDorner
4.5 Stars: 25 Votes
You can over-ride the graphics of the railing element in the view by pre-highlighting it, right clicking and choose over-ride element and select 'transparent'.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Jul 13, 2010 at 2:29:23 AM | transparent glass in elevation
Dafpfy
3.5 Stars: 11 Votes
i want it to be in a normal elevation, and in shaded with edges view,
tnx for all the replys, but those thing do not get the result i want, i want it to be like 50% transparant so you can see the darker shaded glass railing with the window behind it.
peace is the path."
Mahatma Gandhi.
Tue, Jul 13, 2010 at 7:10:45 AM | transparent glass in elevation
As a work around, you might try making the glass transparent and adding a transparent filled region (grey) over the opening.
Thu, Jan 31, 2013 at 11:07:19 PM | Bimman
pdsl
Quoting Bimman from 2010-07-12 14:04:33
Brilliant! :D
Fri, May 10, 2013 at 5:04:28 AM | transparent glass in elevation
domek
or, you could click on the glass (in elevation view) and right-click, override graphics in view, by element, and go to transparncy settings. voila!
Thu, Dec 22, 2016 at 3:43:03 AM | domek
BenNoBe
Quoting domek from 2013-05-10 05:04:28
thanx domek, workef like a charm
any work around for this? transparent glass in shaded elevation views, revit 201
Mon, Jan 28, 2013 at 11:19:53 PM
non-transparent glass
Mon, Dec 4, 2006 at 2:47:13 PM
Making glass transparent
Sun, Apr 30, 2006 at 9:33:38 AM
Glass keeps rendering black not transparent
Mon, Jan 23, 2006 at 4:01:41 AM
Glass in doors transparent only on one side - any ideas?
Sat, Jun 7, 2025 at 1:32:50 PM
Page generation time: 0.2726
