Forums >> Revit Building >> Technical Support >> Grey items!
Sat, Jul 10, 2010 at 1:34:43 AM | Grey items!
Tuppo
Can anyone please explain to my why my objects that I have downloaded from revit city render grey? I know it has something to do with where the objects were created... I have attached an image of the room with grey furniture. Thankyou for your help!
It can also be noted that the bar within the first attachment is black. I believe this has something to do with revit not being able to find the materials!
Sat, Jul 10, 2010 at 12:31:20 PM | Grey items!
4 Stars: 205 Votes
"I believe this has something to do with revit not being able to find the materials!"  - No, there are several threads about this issue, if you look at the bottom of this page you will see some threads with the same questions, I believe those objects (families) are from CAD or Sketchup files, if you edit those families, in Materials you will see the name of the materials (textures) that the author gave to those elements like you can see in the image attached...
In the family, check the names of materials and the render appearence texture, then in project, go to materials and do the same...
Sun, Jul 11, 2010 at 7:36:50 AM | Grey items!
Tuppo
I ticked those boxes in the family edit, it seems to do nothing... When rendering it is still grey.
Sun, Jul 11, 2010 at 7:48:51 AM | Grey items!
4 Stars: 205 Votes
In project check those "Names" in materials and see if they have the right material (texture) you want in Render Appearance...
Existing items in a detail callout
Wed, Oct 20, 2010 at 3:40:57 PM
Yes/No Parameter when checked in Grey
Wed, Jan 12, 2011 at 4:44:35 PM
Why is my default 3D model all grey?
Thu, Jan 5, 2012 at 7:22:09 AM
White walls are dark grey when rendered?
Wed, Aug 10, 2005 at 10:57:54 PM
Tree renders grey
Tue, Oct 7, 2014 at 2:45:44 PM
Page generation time: 0.4665
