9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Windows
18 Posts No Rating |
i have come across yet another problem in my project (I'm new to Revit, but learning all the time!)
i have a curved facade to the front of my building..... where by which i would like to insert a window running all the way round.
however, i have not seen/found a curved window system in any revit library, and cannot figure out how i would go about constructing one in the family editor.
Any ideas?
62 Posts No Rating |
Depending to the results your looking for you could try using a curtain wall system for the band of windows. Of course that portion of your wall would be broken into 3 separate walls stacked on top of each other. Also since it wouldn't be a family you may not get the plan representation you want. Hope that helps you get started.
admin
you probably want to use a curtain wall. If you don't know what that is, take the tutorial, it is VERY helpful.
Hiroshi Jacobs
The Catholic University of America |
thats the only way i could think of gettin around the curving windows, with a curtain wall in in the middle of a stack with the actual walls offset on top and bottom.
i will try it when i next get to a computer with Revit installed.
My Windows are not in my Windows Tab |
Tue, Dec 15, 2009 at 7:02:38 AM
Does Revit 2009/2010 work properly to on Windows 7 |
Thu, Jun 3, 2010 at 4:25:04 AM
12
rendering windows in 2009 |
Wed, Aug 27, 2008 at 8:35:01 AM
Windows 7 and Revit 2010 |
Thu, Nov 18, 2010 at 11:54:09 AM
Need Rakehead windows...... |
Wed, Apr 22, 2009 at 1:15:12 PM
