Forums >> Revit Structure >> Technical Support >> Import model from AutoCAD
Fri, Jul 9, 2010 at 10:33:36 AM | Import model from AutoCAD
archie456
3 Stars: 1 Votes
Hi,
I've modelling a canopy in AutoCAD which I want to import and place on my revit model.
I am thinking that the best way to do this is create  a new Generic Model Family and import the model, apply a material and then place it as a component in my model.
They works generally, but if I import as DWG, I cannot seem to apply a material and Revit keeps seeing it as a DWG file.
I tried IFC, but Revit want to create a new project from the IFC file, I cannot seem to import it into a generic model family.
Whats the best way of doing this?
Cheers.
Fri, Jul 9, 2010 at 11:31:27 AM | Import model from AutoCAD
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
once .dwg is imported.... go to Settings>Object Styles...>Imported Objects> add the materials you want.
 "If you tell the truth, you don't have to remember anything"
Autocad Import Problems
Tue, May 5, 2009 at 1:55:33 PM
import to revit from autocad
Sun, Mar 31, 2013 at 11:37:12 AM
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ]
Sat, Apr 17, 2010 at 7:29:52 PM
20
Having trouble import Autocad files into Revit 2010
Tue, Jun 9, 2009 at 8:55:02 AM
Not understanding how to import 3d aspects of autocad in to REvit to be usable
Tue, May 19, 2009 at 2:58:39 PM
Page generation time: 2.4270
