Forums >> Revit Building >> Technical Support >> Pedestal for HC automatic entry door
Thu, Jul 8, 2010 at 2:04:34 PM | Pedestal for HC automatic entry door
arusso5
Hello all, I'm looking to see if anyone has created, or found, a push button pedestal for an autumatic entry door?  For an instance where the entry is in a storefront and there is no place to mount the automatic door opening button?  I guess I could just create a family, but its easier to d/l one.
I guess I'll get started.
Thanks in advance.
Thu, Jul 8, 2010 at 6:19:27 PM | Pedestal for HC automatic entry door
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I just uploaded a Key Pad Stand, mabe you can modify it.
Fri, Jul 9, 2010 at 7:43:55 AM | Pedestal for HC automatic entry door
arusso5
Thanks mbsteve, but I'm still using Arch 2010... any chance you could repost?
Fri, Jul 9, 2010 at 9:08:10 AM | Pedestal for HC automatic entry door
This is a very easy family so why don't you just do it.  GOOD TIME TO BEGIN
It is nothing more than a vertical extrusion (post).  Then if you want to add the keypad, you could do that on a face of the post.  Decide what will host this if anything.  If it might be outside, then maybe no-host.
Fri, Jul 9, 2010 at 1:00:48 PM | Pedestal for HC automatic entry door
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
just thought I give you a start, it might be 2010, can't remember when it was made, can't go back though, sorry
Rebar placement in concrete pedestal not allowed
Tue, Aug 30, 2011 at 10:11:16 AM
see through door opening to door beyond
Mon, Nov 2, 2009 at 1:46:12 PM
Automatic dimensions to door family defaulting to wrong side of door.
Fri, Jul 22, 2016 at 9:58:33 AM
Automatic Sliding Glass Door
Mon, May 2, 2005 at 10:59:47 PM
Sidelight Constraint
Fri, Apr 28, 2006 at 3:09:47 AM
Page generation time: 1.1270
