Forums >> Revit Building >> Technical Support >> Plan associated levels
Wed, Jul 7, 2010 at 10:22:17 AM | Plan associated levels
MarkBryanDesign7
Is there a way to change the base associated level from the 0'-0" to lets say 1'-0"?
I added levels and the grade level is 0'-0" but the base of the building is 1'-0"
Wed, Jul 7, 2010 at 11:04:21 AM | Plan associated levels
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
in the properties box adjust the view range, when you created levels did you do it in elevation or section?
Revit 2020 - Stairs not showing in plan levels
Sun, May 29, 2022 at 7:23:51 PM
Levels are missing - I tried all solutions on forums no result
Wed, Jan 30, 2013 at 10:57:43 AM
Change a copied lever to an original level
Mon, Apr 19, 2010 at 11:09:14 AM
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
joinery cut at different levels in plan
Fri, Feb 26, 2016 at 4:28:15 AM
Page generation time: 2.9610
