19 Users Online (17 Members):
Forums >> Revit Systems >> Technical Support >> Symbol with rotating text
I am trying to make this Fire Alarm so that no matter what direction the wall is facing, the letter in the tag can be upright. I have tried several approaches with limited scess. The closest I have come is this Fire Alarm with a symbol and letter. If the letter is F it will turn in any direction. If the letter is H it won't turn at all. Does anyone have a better idea for solving this problem? Or, can anyone help figure out why my tag only works on F? Thanks again for all the help. BTY: this family was created in Revit MEP 2010
----------------------------------- ArchWestCY |
1 Posts No Rating |
I'll take another look at it, but it looked like the text rotation portion of the Horn family was alittle different than the strobe one. (one sign was that the default for the Horn rotation family was 45 degrees, and when you change to that type, it doesn't rotate 45 degrees) Not sure the exact fix, but i would reccommend taking a step back and making the family simpler. for instance, instead of having 3+ levels of nested families, maybe just 1-2 levels of nested families. also, each variation of text doesn't need to be its own family. it can all be one parameter. Unless you found a solution already, I hope this helps. I like youre ideas of manipulating the rotation of the text.
I am trying to make this Fire Alarm so that no matter what direction the wall is facing, the letter in the tag can be upright. I have tried several approaches with limited scess. The closest I have come is this Fire Alarm with a symbol and letter. If the letter is F it will turn in any direction. If the letter is H it won't turn at all. Does anyone have a better idea for solving this problem? Or, can anyone help figure out why my tag only works on F? Thanks again for all the help. BTY: this family was created in Revit MEP 2010 ans: try to use the furniture sytem,if does not work the wall system...this is what i did several times to make a family.
Rotating Symbol geometry without rotating leabel |
Wed, May 6, 2009 at 8:33:58 AM
Annotation Symbol Text - Keep Vertical? |
Thu, Dec 15, 2011 at 3:23:42 PM
Photo symbol with non-rotating text |
Mon, Jul 14, 2014 at 11:36:09 AM
Symbol Text |
Thu, Dec 10, 2009 at 5:39:08 PM
sloped annotation symbol text |
Mon, Aug 15, 2011 at 8:04:20 PM
