Forums >> Revit Structure >> Technical Support >> top primary range
Wed, Jul 7, 2010 at 12:51:55 AM | top primary range
CNMSD
Hey, I've read as much as I can bout the view range and it still seems to not do what I want it to. I've got a cut plane 200mm above my portal frame knee joint and a bottom range of -1200mm. I'm trying to see the arch. roof underlay so I've set the top range to 3000mm. It doesn't matter what I set this to it just seems to be the same. FYI all the ranges are set to the associated level of the portal frame knee joint.
Thanks..
Wed, Jul 7, 2010 at 11:15:12 AM | top primary range
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I cannot tell from your question what it is that you want to do. As far as view ranges are concerned the primary consideration is the cut plane this is the elevation that a slice is made through the building.
Wall Sweep Visibility
Mon, May 23, 2016 at 3:58:50 PM
new to revit
Sun, Jun 3, 2007 at 4:29:48 PM
Issue with making a not primary option the primary Design Options Revit 9.0
Wed, Jun 4, 2008 at 5:52:15 PM
view range top clip plane
Sat, Jan 24, 2009 at 7:56:31 AM
Why isnt the Range Top, knobs and door handle not showing up in my Rendering
Thu, Dec 4, 2014 at 12:30:50 PM
Page generation time: 8.0347
