30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> Callouts are funny
14 Posts No Rating |
I have been stumped for a while and was unable to find anything searching the old forum threads... I have in front of me now an elevation that should have two building section callouts in it. Only one shows. I checked the VG and for hidden objects. It does the same thing on the opposite elevation where the same two should building section callouts should show. A cross directional section does show both building sections in question. I tried adjusting the extent of the section to make sure it crosses the elevation plane. But in another post to a similar problem: WWHubsite moderator Joined Tue, May 16, 20065427 Posts Change your scale to a larger one and see if they rea-appear. If they do, then you have to change the setting for hiding the callout in the smaller scales. So I tried this and the both sections show up when I change the scale to anything larger or smaller than 3/16" = 1'... I have been using Revit a good while but I am not sure what WWHub is referring two with hiding (or not) callouts by scale. I am using old fashioned 2010 Revit Architecture. All sections and elevations are at 3/16" scale. Thanks!!
Still stumbling. I tried recreating the problem in a new file but without success. I place a new section in the area... but it has the same issue. I change the callout to a wall section, still dissapears when it goes to 3/16" or 1/8" or smaller.
SO NOW I find the hide at scales courser than option.... I scanned the section cut properties several times before and missed this. Apparently building section automatically set this to the scale they are created in. I am not sure how this basic function has eluded me.. but now I know and knowing is half the battle.
Are Callouts Vew Specific? |
Wed, May 12, 2010 at 3:56:06 PM
HELP! callouts are not visible!! |
Sat, Feb 16, 2008 at 12:17:21 PM
Callouts and Callout Sim Views |
Thu, Sep 12, 2013 at 10:41:57 AM
multiple section callouts |
Wed, Jun 4, 2008 at 9:04:18 AM
Visibility of callouts |
Fri, Nov 11, 2011 at 3:04:48 PM
